I'll admit when I'm wrong
Dude, so sorry. Put the new engine and transmission in, went to put A/C compressor in, and realized it didn't fit. YES, I did remove it before with the engine in...HOWEVER - I lifted the engine up with the hoist a few inches to slide it out.
You *could* try unbolting the engine mounts and jacking the engine up a few inches. BE SURE not to go too high or you'll come off the mounts and terrible things will ensue...otherwise, yeah, you're dropping the subframe. I'd lift the motor before dropping the subframe, only because I've never dropped the subframe and those are some MEAN looking bolts.
