Need help - Low compression ratio engines and drivability
vqpwrd240
Car: 93 S13 and 97 Maxima
Well, I need to know how the car will drive if I put in a built ka24de with an 8.6: 1 C.R. but no turbo for now. So will it drive well? I wold like to put the engine in now and then after winter add the turbo system. This way the engine can have time to break in with no boost. I do not want to do any damage to the built engine and I do not want the car to act weird or have anything go wrong. I know the car would have less power because of the compression being lower than stock. Will I have to do anything with the ecu to have it drive as normal as possible over the winter? Any help would be great. Thanks in advance.
Ferhan
480sx
Car: 1996 Pearl White 240sx
Your car will run like a champ, you wont really notice any differance.
You'v got a good plan btw, just make sure you break your engine in right and you will have a good platform for a turbocharger.
vqpwrd240
Thanks 480sx. So I really have nothing to worry about. No need for ecu or tuning changes at this time? Will have no intention of screwing arounf with the car over the winter, so I will break it in right.
DevilMB3017
The only thing I noticed was after going lower compression with no turbo was regular gas is much better. If you use prem. fuel, you'll spit it all out the tail pipe.
scheffler
Car: 92 240 KA-T
92 300zx TT
97 Tahoe
I did the same thing that you are talking about. It ran great. I didnt do any changes to the ecu. I have 8.5 comp pistons and ran it with stock everything until i put my turbo on.
vqpwrd240
Thanks guys. How would head work and cams affect the engine without the turbo? Also are cams even worth it on the KA? I was planning on having / building a custom intake manifold as well later on to get more air into the engine. Ideas?
Ferhan
WDRacing
Lowering compression WILL effect driving, but it's hardly noticeable at all. It also effect efficiency and gas mileage as well...for the worse. But again, not really noticeable. I'm just telling you so you're aware. Lowering compression allows to add boost or timing. I suggest, if you're going to run 91 or better, that you bump the stock timing up a tad. You throttle tip in will be crisper and the car should "feel" more responsive.
But no tuning or anything is required simply to run lower compression pistons. Hell I had my compression in the 7's on my RB20. But it was purpose built for drag only and ran 28 psi of boost as a minimum.
WD
spooled240
Car: kouki s14
I am thinking he could lean out his engine a tad since his compression is lower. Sort of the reverse logic in adding more fuel for more compression, right? He could save a little more gas if its an issue.btw, great way to start off a turbo build!
eazye2000
Car: S13 KA-DET
...sounds logical me thinks. Take some fuel away if that's at all possible. Or if you don't want to do that, crank the dizzy and advance her a bit. And running the 'cheap' gas would be awesome! I wish I could do it.. lolAlthough my car has 8.8 Arias stock bore pistons, I have a .080" head gasket. Which is 2mm I think? I've never calculated the actual compression ratio, but it's pretty low. I can make lots of boost!! yay!!
vqpwrd240
Thanks everyone. What about the head work and cams? If I am running stage two or stage three cams. Will the car run fine? Will I need to get a ecu upgrade? Thanks.
Ferhan
480sx
You can just drop cams in but if you do you arnt getting your moneys worth. You really need a tune to accommodate the different amount of air being introduced to the combustion chamber by the longer duration cams.
It will run fine though.
240sxfan6882
Car: 1995 240sx
You'll be ok. I been running with lower compression built KA for over a year now. I just took my time piecing stuff out. I noticed my car makes less power...but thats cause of less compression and i have 18x9.5 wheels..compared to stock steelies. Gas mileage is still good...i just get more backfires. thats all.
Zippy69
Car: 1993 240sx coupe
If you are backfiring, then it is a timing issue, not compression. Bump your timing up a few and you will burn your fuel more efficiently, and no more backfire.
spooled240
Car: kouki s14
if air gets into the exhaust system or just going catless will create some backfires.my buddies mani cracked and he said he was backfiring cuz the air was getting in his exhaust system through the crack. Sounds tight tho lol
