Need help locating the coolant temp. sensor
94NissanSentraLE
Hello everyone!I have a 1994 Nissan Sentra that I need to replace the coolant temp. sensor. The problem is, I don't know where its located. Can anyone give me specific instructions on finding it?
nametakennow
Car: '06 MINI Cooper S
Someone around here is sure to know, but that person is not me. Would have been better to post in a Technical section, but it'll be found. Here's a bump for good luck. Techies, where you be?
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Its over by the AIC valve. Will be a complete pain in the *** to get too!
94NissanSentraLE
Hey, I just want to say thanks for the info. I do have one more problem though. Is there a special tool to disconnect the connector which connects the wire to the sensor? Or can I use a regular pair of needle nose pliers to just snap it loose?
RED_DET
Vendor
2011 Infiniti G37x
No special tools required. Should pull right off.
