BruceJ30 »
https://forums.nicoclub.com/brucej30-u79724.html
Thu Sep 11, 2008 3:25 pm
Yeah, it's the fuel pump relay.If i'm not mistaken, 2 of the parallel plugs should begetting twelve volts, and two parallel getting ground.
Well i have the two parallel that are supposed to be gettingpower, that's all fine.But for some reason (this is where i need help) the two for groundonly has one grounded and the other is getting power to it.
And yes, it is a no start problem.But when we bypassed the relay temporarily, it started right up.But... It was shaking a good bit. I do believe this is injector related.Because i have had an injector go out and came back by itself.So this car has some electrical issues.
But i checked all the grounds that the relay has and any others i couldfind, also cleaned them. So the grounds are fine, i just need to figure outwhy the ground is getting 12 volts...
