MeanGreenS13 wrote:A tire is irrelivent. He asked nothing about what tire he should use.
SURE he should be on a drag radial or even a slick. But dumping the clutch not only causes tire spin, but drivetrain shock, which breaks things. And a 2.1 60 foot is absolutely PATHETIC!, i can do a 1.8 all day long on street tires with my technicque. it works perfectly.
I dont care what your buddy pulled dumping the clutch, his car is either probably AWD, or he got lucky. Dumping the clutch is only your gateway to broken parts... even if your stock
I did not mention anything about what tire he should use?! Where did you get that? I just said that he should adjust his tire pressure.
Using your technique can fry a clutch for the unexperienced driver. I have made 100s of runs using my technique and nothing has broken ever! Sure with more hp it could break things, but these are sub-170 hp cars we are talking about! A 2.1 60 foot with a stock front wheel drive (open diff with factory tires) Sentra (140hp) is extremely good. There is no way you could break 2.0 with your technique or any technique with that car..... You can not compare your rwd 300+hp car to a car with not even half the power!
Furthermore, my friend's eclipse was fwd and yes he did get lucky.....basically he heated the tires up off boost and when the boost kicked in it stuck.
Modified by justjuiceit4 at 4:45 PM 3/17/2008
