Need help just messed up my whole suspension..
Salvadorian561
Car: 96 240sx se
Hey guys im new to the car world and I just recently got me a s14.. I lost control of my car and jumped a curve. now my rear left wheel is dented in but I dont know whats the problem? If you guys could help ,e out I would appreciate it.. I tried searching but no luck..
Salvadorian561
Car: 96 240sx se
Here are some pics
Warped161
Car: 90 s13 the never ending project
remove the wheel and give us some pics of the suspension, compare the driver and passenger sides of the rear to see if anything looks bent or broken.
MastaYu
Car: 92 Nissan 240SX SE HB
more pics needed
Salvadorian561
Car: 96 240sx se
I looked on the other side and the bushings on my left side are bent?
Salvadorian561
Car: 96 240sx se
Heres a pic of my right side and also I just put in a z32 diff and when I drive my car I hear this noise coming from the rear. Like if its rubbing on something.
Warped161
which bushing is bent?
Salvadorian561
Car: 96 240sx se
my left side when I look at it and compare it to the right it is slightly. Where the RUCAS connect to the knuckle
97240SE
Car: 1997 Nissan 240sx SE
that noise is probably your axle due to the wheel being off so much, you possibly bent the control arm/bracket
jfryjfry
Car: 1991 180sx
bushings are rubber -- they don't bend.
likely your control arms and possibly the mounts on the 'frame' where they mount to the body are bent.
you should replace the ball joints too -- if you fractured one, it could let go and that's not a fun or cheap experience.
take it to a reputable shop. you can save $$$ buy providing known good replacment parts to them to install.
Salvadorian561
Car: 96 240sx se
Nvm guys I found out that my rear left knuckle is cracked.
