Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Mon Nov 26, 2007 7:47 pm
I usually recomend using 15w50 for warm months an switching to 10w30 for cold months.
so long as you use 90 weight gear oil, it really doesn't matter what brand you use. Just use a quality brand. If you like royal purple, go for it.
For usin a KA radiator, I fab up a crossover pipe with two 90 degree radiator hose elbows. If you go with the KA rad, you will have to switch to an electric fan.
I don't quite understand what you're asking about the trans. Are you talking about the big dust collar on the end of the transmission? If so, remove it. It's not needed and gets in the way.
I would recommend not bumping an hour old thread. It's late and a lot of people are asleep so responses will be slow
