corey240 »
https://forums.nicoclub.com/corey240-u32370.html
Sat Apr 14, 2007 6:22 pm
heres what you do to know if your getting spark, which means in my case and possibly yours, you may be flooding. take the fuse out for the fuel pump, then tryn and start it and give it a little gas, if it turns on it was turn off almost immediatly. so if it starts like this but not the other, then you are flooding the engine. also, you may already be flooded. dont ask me how to fix this because im still working on it. so if that doesnt work...
take out your spark plugs and unplug the cas and fuel pump fuse and try keep turning the ignition until you dont see anymore gas blowing out of the holes, good to have a buddy to help with watching that. then try and start it.
