LOL> did u swap the speed sensor? no. you didnt. go put the ka harness on the transmission. i did same mistake, i just forgot.lil_vang wrote:i know the stock gauge doesn't work so will i need to get a jdm or 92 up gauge cluster so i can get my speedometer working??
LOL> myth my ***. if they are different. most of the time u dont need em because u talking about swaping s13 into s13.if u do any hybrids, u need to swap sensor/harness.Jesse SR20 wrote:
The speedo will interpret the signal from the speed sensor whether it's USDM or JDM just the same.
Also, you don't need to use the KA transmission harness either. I used the JDM sensor and harness.
