Bugaboo wrote:where is the fuel filter located?
Engine compartment, passenger side, lower rear corner, sort of behind and below the power steering reservoir. Should be bare metal silver in color with two very tough-to-remove hoses connected.
Remove the system pressure and then loosen the gas cap before disconnecting, on a cool day, and clamp/plug the fuel lines while it's disconnected.
The engine will idle on only four cylinders (possibly only three?) and start on five (maybe four or less?), so it's bound to be something that's affecting the overall supply of fuel, spark or air to the engine, if there's compression.
300K miles. Very impressive.
