NEED HELP ISO SINGLE CAM OIL PAN
griz_s13
Car: 1990 nissan 240sx
Going on 2 months now and can't seem to find an oil pan for my car. searched everywhere even junkyards :mad:
Can someone help guide me in the right direction?
car has been down 2 months now.
I ordered this oil pan because I was told it would be a direct fit for a single cam.
pattern doesn't match my gasket.
http://www.ebay.com/itm/REV9-ALUMINUM-O ... 5-&vxp=mtr
griz_s13
doing some more research now i didnt realize i need to order an upper oil pan. so i guess thats the route that i will have to go with.
bolt patterns are the same as a dohc from what ive read so the upper should be a direct fit to the sohc as well correct?
i did read a dohc pan does not clear on a sohc also. is anyone running this set up on a single cam??
PapaSmurf2k3
Site Admin
Might want to try giving Courtesyparts a call and seeing if they can make heads or tails of your situation. They probably have pictures and part numbers you can reference.
Also, have you looked at the FSM to see if there's an exploded view diagram?
www.nicoclub.com/fsm
sky5031
Car: ???? Nissan 200SX
???? Nissan 240SX
???? Nissan 300ZX
???? Nissan Altima
???? Nissan Frontier
Is this engine you have the ka24e engine? This engine was also used in the acxess van , I believe that pan will fit your engine.
