Need Help Interior Lights!
Kenrik
Car: Nissan 240SX Coupe
Infiniti G35 Coupe
Nissan Versa Hatch
Ok so I was installing new LED bulbs in my map light and the two contacts touched each other. I heard a noise and the lights went out.
So! I checked the fuses and i did not find any busted. (none are marked dome light)
My map light and my door lights are not working. The trunk light and the dash lights ARE working.
What did I fry??
What's the correct fuse for the interior lights?
Is it possible I damaged the BCM>? if so it's possible to break just part of the BCM?
How do I fix this!!! ???
I checked the FSM but it seems the section for "LT" is incomplete/the PDF is busted.
Help.
Kenrik
Infiniti G35 Coupe
Nissan Versa Hatch
I disconnected the Negative battery cable and reconnected it...
I am now the Proud Owner of a 48 LED dome light..
DAM it's Bright!!
Yes kiddies I did say 48 LEDs... It will blind you..
smockers83
Car: 2006 G35 Coupe
Pics?
Beancooker
Car: Current Car: 2024 Tesla Model 3
Past cars: Way too many to list
I have 12 in each map light, and I could do surgery if I chose to. I can't imagine what 48 of them look like.
For the FSM, you need to Right click "save target as", otherwise the FSM's don't work well, and come up kind of, well, incomplete.
Kenrik
Infiniti G35 Coupe
Nissan Versa Hatch
Beancooker wrote:I have 12 in each map light, and I could do surgery if I chose to. I can't imagine what 48 of them look like.
I have 24 in each side (two 12 light kits wired together)
it's basically 2X as bright as a 24 LED (12 in each) kit
I'll post pics later.
I tried "save target as" it still downloaded missing stuff.
