NEED HELP installing distributer>>>HURRY, NEED ASAP
mirra32
well on my 95 ka24de that i have installed, i will be using a 93 distributer. so when i took off the old one i alighned the distributer cap so that the prong thing was exactly on cylinder # 1...so my question is can i install the new distibuter so that it is also alighned with #1 just like the one i took off.....if not can someone give me the steps to install a distributer.....or a link...i did a search and did not find much usefull
eric
mirra32
http://www.240sx.org/faq/index.html
Found this
Distributor Timing
The pupose of this faq is to show how to get the distributor in the correct timing position.
1st locate your front main pully Understand the markings on the pully, if you can't see them, turn with a socket wrench clockwise (pretty tuff) Make sure that you have the spark plug wires on the correct cylinders Check that the rotor on the distributor is in the #1 cylinder position at TDC; don't be alarmed if it is in the #4 cylinder position b/c it can be in both, just spin the pully another 360 degrees to get it to normal position (Also see next pic)
This is what it needs to look like when putting back together A pic of the inside of the distributor cap
Modified by mirra32 at 9:40 AM 5/5/2005
