scooterbob »
https://forums.nicoclub.com/scooterbob-u82760.html
Fri Mar 27, 2009 12:42 am
Welcome to the forum.A person would need to know where you are intending to mount the amp in order to give exact details, but here are the general ones:I mounted my amp on the back of the rear seat. I pulled the trim along the door kick plates and zip tied the wires with the rest already in that pathway. As far as the firewall, I just poked a second hole into the rubber grommet where the main wire harness passes through (careful not to damage the harness). If mounting the amp under the seat, it would be a little different, but not much I would imagine. Regardless, a fused link in the power wire is a must, but I would have to guess you know this from past installs. The rest is pretty similiar to any other car. Popping the trim is pretty basic.
Good luck!
