iam_so_slow wrote:hmm i also have a few more questions =XX
umm i was wondering where is the courtesy light? =Xalso like for the H1/6 wire where do i find the trunk wires? do they run next to the driver side door like a red and a blue or something?
umm....as for the ignition wires is it ok if i splice further up the wire like the white wire turns into a white/red iirc... i spliced the white/red i hope its ok...-thankss
You can splice it anywhere. Just don't get the wires mixed up when the color changes.
For Nissan_S15_240sx... wow, you sure spent quite a bit of money on your swap. I would really like to see your car if you have images of it. For me, everything that is done to it, I did myself. Not sure why I attempted a S14 SR swap into my S13 chasis but I did. Took the wiring to a local shop and they were clueless so I had to attempt it myself. I was sure I'd fail miserably and already was gonna get a new wiring harness from courtesy parts. Surprisingly it worked. I was so sure it wasn't going to work, otherwise, I would of done a write up. Anyway, hope you have better luck with XAT and keep us up to date with your progress. For me, I'm shooting for maybe 350hp, don't want it to be a gas guzzler especially when gas prices are so high. Gonna insolate it with some rubberized spray and make it as comfortable as possible. Want it to be a nice quick car I could go cross country cruising with and not have to stop every 10 blocks for gas... if you know what I mean. Anyway, good luck!
