need help installing a new Head unit
D_roc
Car: 2001 Maxima 20th aniv edition
ok this mught be a stupid question but i want to know what will happen if i hooked the speaker wires on my new headunit to the bose amp instead of the pre amp outputs? I thought the bose amp/speakes were good quality but recently i added 2 12" and now the bass is way louder so i can't hear a thing except the bass, the bass boost is in 0 and pretty much every setting on the amp is as low as it goes and still, so is there any way to make the bose speakes go louder right now i have no money to invest in a new amp and speakersthanks D
jltibbs
Car: 2015 Nissan Versa SL
1994 Infiniti Q45
2000 Infiniti I30
if you hook the radio directly to the bose amps you are going to add the power of the radio to the amp which will cause distortion. i just recently put my aftermarket head unit in my 94 Q which came with bose. i am not happy with it at all. i can barely turn my stereo up. i think i will change out the bose for aftermarket so i can get some more sound out. the bose is set up for quality, not loudness.
D_roc
can i lower the power a little bit by adding a resistor or something?, by the way what happen to your other nissan not the max
jltibbs
1994 Infiniti Q45
2000 Infiniti I30
you can use a resistor or this
are you talking about the 240sx i had? someone side swiped me two months after i totaled the maxima
