crazywild »
https://forums.nicoclub.com/crazywild-u30342.html
Tue Jul 05, 2005 1:56 pm
well the maitenance manual doesnt help much, only to unplug the sensors on the transmission then remove the propeller shaft and support the transmission with a jack then remove the slave cylinder and starter, and unbolt, the only thing you might need is the exact torque for each bolt as you put them in.
one last thing i found to help a poop load is to take out the passenger side motor mount and let it drop down as far as it goes so you can remove the trans and stab it in a lot easier, this i did using jackstands also and am onto my second clutch since the one i replaced last year was a defect but luckily was under warranty. good luck
