r34 gtr »
https://forums.nicoclub.com/r34-gtr-u3863.html
Fri May 18, 2007 8:18 am
unplug and pull back the part of the wiring harness that runs above the manifold and injectors (cas, coolant temp, injectors, fast idle junk). remove the screws/bolts holding down the bracket for the fuel rail. remove rail, the injectors should more or less come out with it. replace injectors. reinstall junk.
