uniwander »
https://forums.nicoclub.com/uniwander-u44848.html
Sun Aug 06, 2006 12:29 pm
I had something wrong with the audio system of the 1994 J30: the whole system including CD, radio and tape doesn't work suddenly. Here is the email from the first owner:
"this happened to me a couple times a few years agoduring the start of winter, and then stopped from then on.There must be aloose or corroded power or ground connectionon the head unit in the dash. Ifound that to temporarily solve the problem, the radio came back on when Iwent over a large bump. To reproduce this, I tried lightly hitting the rightside of the center console (big plastic piece), just onthe right side of the radio. This worked every time. To fix it permanently, you might try using some dielectric grease on the power leads on the back of the radio, but it takes some work to get it out."
Now the audio stops working completely. I removed the stereo this afternoon and found it is almost impossible to remove the 4 screws on the bracket. I also tested the power leads on the back of the stereo and seemed no problem.
Thanks.
Li
