NEED HELP IN INDIANA
sheldon
Car: 95 240sx with rb25det
ok i have a 95 240SX with rb25det , and im having so problams getting it to run right. ive changed spark plug 2 times the gap was set at .8mm . it will run kinda good for a bit then it starts to miss fire or studers, i have a q45tb an q45maf with a apexi neo and a avc-r boost controller . i would like to find someone that would also be willing to look at im cloes to the Fort wyane area .
Carl H
what series rb25?
maryjane
neo setting could be off.
try getting the ecu rom tuned to the maf n tb you have on the car
sheldon
series1 an r33 ecu what ive been told an can tell
Modified by sheldon at 8:20 PM 8/2/2009
sheldon
does anyone know a good shop that would be able to help get the project done . . .also does anyone know what the neo hot wire setting should be at ?
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
Your about 3.5 hrs from me.What other modifications do you have done. May want to consider going back to the stock TB.
Only places that I know of are in Indy.
Per A'Pexi's site: Red wire: IG Power (Ignition PWR)Green wire: RPM (tach signal) Red and white wire: IG Power (Ignition PWR)Gray wire: Throttle signal (TPS Sensor)Brown wire: GroundBlack wire: GroundYellow wire: Airflow & Pressure Signal OutputWhite wire: Airflow & Pressure Signal InputOrange wire: Illumination Power
Via http://www.apexi-usa.com/CONTENT/PDF6176.PDF
EVILS14
Car: 1995 NISSAN 240SX SE RB25DET
there is a place in dayton ohio its only 2.5 hours from you called forced fab they do great work and they are really good people to deal with
sheldon
thanks for letting me know about forced fab im sure i can find there number . but i have to ask are they any good with rb's ? as far as the engine , it has a greedy intake manifold, stock turbo,stock injectors, 12x24x3 front mount hks blov, 3 inch ss exasust with cat and the rest is up above .
EVILS14
oh yeah when you call ask for a guy named joel when i cant figure out whats wrong with mine i go to him. like i said he is really good to deal with and he wont a@# rape you he did my wiring in mine for $150 here is the number 937 242 6392 they are open from 11 to 7 mon- fri sat by app
sheldon
wow i got screwed on my harness . an after i got mine back i had to run power to the ecu and fuel pump. long story short . so im not 100% sure if everthing is working because of that either now i have no wippers an im not sure about cruse . . so should i tell him that you refer me
EVILS14
yes tell them erik refered you
sheldon
EVILS14 wrote:yes tell them erik refered you
hey thanks erik i talked to them an they seem to know there suff and seem to be great guys to deal with . thanks for poniting me in there direction. i may just have them rom tune it while its there. after there fix the problems. lol
sheldon
l0nestar wrote:Your about 3.5 hrs from me.What other modifications do you have done. May want to consider going back to the stock TB.
what place's do u know in indy
