It can be a bad ground or a weak source of 12v+. The relay buzzes because it does not have enough power to fully open. Roger had the fuse out when he heard the buzz so the relay was probably getting a weak signal from the ecu that was too weak to open relay.duckdodgers69 wrote:the buzzing noise you here from under the dash is a relay or flasher or the voltage regulator on the cluster thats from not egnuff ground.
