bgoodwill »
https://forums.nicoclub.com/bgoodwill-u49778.html
Sun Oct 29, 2006 6:05 am
I'm a novice here, so please bear with me.
I believe #4 is dead when idling because if you pull that wire, there is no change in how engine runs. If you pulls any of the other wires, the engine bogs down (even more). Have tested the wire and it's getting current. Have looked at and even changed plug and that's not the problem, either.
It could be dead all the time, but the engine smooths out and seems to be running as normal when you increase the rpms. I'm not feeling any loss of power or performance change when driving, so I assume that cyclinder is kicking in somewhere along the line, but maybe it just runs okay on 3 cyclinders, although I'm not sure how that could be right.
I'm thinking maybe I should clean out/change out the fuel rail but somebody told me that's probably not going to help.
