Need Help Identifying Turbo
TrueSlide
Car: Stuff
Well I was over a friends house and he had a ****load of turbos over at his house and said I could have one. Well I took the 2nd biggest one, the biggest was a turbo from a 18wheeler. Well I do not know what type of turbo it is. Here is some info if anyone can tell me.
On the turbo side where the filter goes it says:
BCC A/R 42 GARRETT e43
Then it has a metal tag on the backside with this info:
CUST P/N: 75 2140ATU P/N: 46 6420-2S/N: NL 1 1 6 4AMODEL NUM: TB0339
The turbo is in need of a rebuild. Are they hard to rebuild? I have never taken one apart before and where could I get a rebuild kit.
Thanks!!
TrueSlide
Car: Stuff
This is the post :) Also does if no one knows the type of turbo do you know where I could find out? Or know GARRETTS number??
TrueSlide
Car: Stuff
No one knows? Everyone talks about turbos, and no one knows what type of turbo this is?
Zebrahead
Car: cars, basketball, girls, fishing
Maybe you should try the turbo forum, or the tech forum.
Nick.
Sygerwulf
Car: 91 240SX SE
Do you have any idea what it came off of?
redrocket
Car: 1987 Nissan 200SX SE
2007 Chevy Silverado Classic Crew Cab
1999 Kawasaki ZX9R
try contacting Garrett and see if you can get specs using part numbers and things
nametakennow
Car: '06 MINI Cooper S
Dude, he said "Here, pick a turbo." Where'd he get them? That's odd that he'd have some sitting around.
SpeedRacer1
Car: 1990 240SX, G35
Well im not sure if this helps but I found this turbo. It says BCC A/R .42 Garret, not sure about the E43. Its an RX-7 Turbo II. Heres a couple pics and heres where they came from.
http://www.thedodgegarage.com/turbo_con.html
