480sx »
https://forums.nicoclub.com/480sx-u50548.html
Fri Jan 18, 2008 6:21 pm
We cant tell you a damned thing about the turbo specs wise.
What you need to do is take measurements with a mic of the wheels to figure out what trim it is. It looks like a hugee exhaust housing though. If you go to garretts website, and go to the turbo tech section it tells you how to do all that. You can get a cheap mic for under 10 bucks and it does the same thing as a fancy one. A mic is a nice thing to have, you'll definitely use it more than once.
As far as a downpipe goes, your going to have to have a custom one made. For the flange that will go up against it, it looks like a normal two bolt exhaust flange, you lucked out there. You can pick one up from this website. Just figure out how big the hole is, and order the right flange.
http://www.roadraceengineering...s.htm
