Hey guys i havent posted much before as i just got my 240 about a month ago but i haven been planning a turbo ka 240 project for well over a year anyways.
i got a turbo lying around and before i piece it together i need to identify some parts of it
the turbo was out of a volvo it was originally a t3 with e .48 turbine and a .42 ar comp side
i have disassembled this turbo and im going to put a t4 comp housing and change the turbine housing to a .68
i have a airesearch t04 comp housing its labeled s trim and says 60 a/r on it i wanted to know which compressor map applies to this comp housing and inducer wheel, the inducer wheel size is 34mm.
here are some pics of it
thanks
Modified by scarboroughdub at 10:13 PM 7/4/2005
i want to reach 400whp the setup is going to be custom fabbed by me as i work for a shop the only debate i have now is what ems to use im thinking between perfect power prs4 and the emanage ultimate, as for the turbo choice depending on the math i may have to redesign this turbo but since i got it all for free the housing and the wheel and the actual t3 im trying to work with it to save some $ if i cannot use it i will buy other parts to reach the 400whp goal.
Postby
hannibal »
https://forums.nicoclub.com/hannibal-u1252.htmlWed Jul 06, 2005 6:51 am
So basically youre only keeping the center bearing section of the Volvo T3??
I dont see a T04 comp wheel with a 34mm (1.339") inducer. Maybe its a AiResearch wheel. Its hard to find info on them, cause I think they were bought out by Garrett.http://64.225.76.178/catalog/comp_wheels.html
thanks for the link, it definitly is a airesearch housing and wheel and it appears to be a standard shaft size since in still using the .48 turbine from the volvo turbo, the strange thing is the inducer wheel is 34mm or 1.333inches which equates to a t3 wheel on the spread sheet you have linked so im confused now.
Modified by scarboroughdub at 12:03 PM 7/6/2005
