biosehnsucht wrote:being grey I'd take that to be F9, altho it might be F8 ... its one or the other. Is that the US side or the JDM side? either way its one of the two.. RHD version only has F8 whereas LHD (euro) has F8 and F9, and the pinouts for the two F8 versions aren't 100% the same either.
The other 3 pin connector I'm not sure.. doesn't show up in either RHD or LHD euro harness depictions
A I thought it was F9 as well, but the wires weren't matching. Another problem is that few wires were up in the air because I was looking at the euro manual and things simply didn't match. I've found all but two wires.The small one ends up at pin 55, the ambient air sensor, which I don't have, and it also goes to the FICD. It's only two wires, btw.The others go to a number of sensors and relays, I might just get rid of the other connectors and route things how I want it. I'll have to anyway, the harness is far too long as it is.
