onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Wed Nov 16, 2005 3:12 pm
new subframe as in new subframe bushings??? You can get that from one of our sponsors or from ebay.
The noise from your rear is probably either the subframe as you mentioned if it is "tore" up, or maybe the wheel bearing starting to go out. I'm guessing you've never changed anything back there, so could be a bunch of different worn out bushings... or even your pads going bad or rotors getting warped.
New wheel bearing I would go w/ the dealership, You can call the midway parts team (our sponsor) their banner is usually to the right or left of the pages, or on the main page.
Keep in mind, you will still need to get the old bearing pressed out and the new one pressed in.
You will get charged depending on how much they like you.
