still learning 06 »
https://forums.nicoclub.com/still-learning-06-u49215.html
Mon Oct 01, 2007 2:51 am
I don't believe that you'll be able to differentiate a V-spec from a non v-spec model by looking at the motor. My understanding is mechanically, (non-aesthetics, i.e CF diffusers, etc.) the V-spec model had the "rear wheel steering/1 degree movement option and that's it. I may be wrong, but with a front end clip...it may be tough/impossible to determine.
As for the rear susp. assembly, I've never really removed or worked on one enough to tell you what to look for. "The mad scientist" is all knowing and will be able to answer your questions more accurately I'm sure...hit him up.
