Need Help- Have code 1446 EVAP
JonathanPrem
Car: 02 Nissan pathfinder 4WD SE
I got a code on my pathfinder for p1146. The code says its Vent control valve but I read that it might be broken evap canister but want to make sure. I also have code few months ago for 1456- small evap leak which i thought was loose gas cap since i forgot to tighten it.
Any one know where the canister is located and how to replace or fix this problem.
Please and Thanks
qx4girl
Car: 1997 Infiniti QX4 4X4
The canister is (should be) in the back by the spare tire on the driver's side. It's about the size of a paper back book.
I just had to replace my air intake elbow, so if tightening your gas cap didn't work, I would definitely check into that. Also though, the small evap leak could be the O-ring for the vent control valve.
