maxhopper »
https://forums.nicoclub.com/maxhopper-u11180.html
Thu Jun 15, 2006 12:27 pm
Here is what I have for the removal procedure. If you have problems with, or modifications to, any of the directions, just post up. These directions are inclusive to models with Nav.
1. Remove DVD-map disk to avoid damage.2. Remove RH instrument lower cover(below golve box area). 3. Remove instrument passenger lower panel and glove box assembly. 4. Remove lower driver instrument panel(below steering wheel). 5. Remove shift knob and M/T or A/T console finisher. Disconnect all harnesses.
6. Remove cluster lid C. A. Remove screws from bottom of cluster lid C. B. Pull lid towards rear of vehicle to release clips. Disconnect electrical connector.
7. Remove cluster lid D. B. Remove screws. Pull lid toward rear of vehicle to release clips. Disconnect electrical connector.
8. Remove screws from front of NAVI control unit.9. Pull the carpet on the left of console aside and remove screws.10. Disconnect NAVI control unit connectors.11. Remove NAVI control unit.12. Remove screws and remove center stack. Disconnect electrical harnesses.
Installation is the reverse.
