need help getting my sr20 to crank!!!!
90coupesr20
Car: 1990 Nissan 240sx Coupe
Ok so i just did the s13 sr20 swap in a 90 coupe i rebuilt the motor and put it in the car and i get no crank or fire i turn the key and nothing happens, no clicking noise coming from the relays, no starter turning no nothing. if u can help me get it running i would appreciate it.
thank you
90coupesr20
dre1507
flashy red button at the top. yea, it even flashes.
raremotive
Car: 04 Infiniti G35
Hello and welcome.
You are more likely to get ridiculed at this section of the forum.
I suggest posting at EITHER:
SR rwdhttp://forums.nicoclub.com/zeroforum/138
SR fwdhttp://forums.nicoclub.com/zeroforum/169
or 240 Technicalhttp://forums.nicoclub.com/zeroforum?id=17
dre1507
OMG. i feel so ashamed. i swore to myself i would never ever be that guy. Jeez. now you got me feeling all bad and stuff. you're in a panic because you're swap isn't producing the results you want and here i am kicking you while you're down. hey man, im so sorry. do as f8 says. But also make note that the search bar often yields answers faster. Welcome!
PapaSmurf2k3
Site Admin
I'll move this thread to the RWD SR subforum.
Morph
Car: 91 Sr Powered Coupe
90coupesr20 wrote:Ok so i just did the s13 sr20 swap in a 90 coupe i rebuilt the motor and put it in the car and i get no crank or fire i turn the key and nothing happens, no clicking noise coming from the relays, no starter turning no nothing. if u can help me get it running i would appreciate it.
thank you
90coupesr20
K gonna need some more info
Is your fuel pump turning on?Battery good? Now dont just say ya accessories turn on cause having enough power to run the radio and fans doesnt equal enough power to start the car. Is there power going to the starter?Can you push start the car. Did you check for blow fuses?
90coupesr20
i have enough juice that battery is brand new i oulled the harness and the kid that had it before me chopped into it so im just gonna get a new one.
snake240
Car: 92 hatch SR20DET
did you swap auto to manual transmission?
90coupesr20
the car was manual to begin with
