Need help! Frost on the inside of my windshield.
All things Altima Coupe.
dldjros69
Car: 2012 Evo Gsr
A/C 2.5 Turbo 6MT (SOLD)
I live in PA. Yesterday the temperature in the day rose to about 40 degrees and then at night the temp dropped to 20 degrees. This morning the temperature was 10 degrees.
The "inside" of my windshield was covered in frost. I had to let my car warm up for about 20 minutes and use a rag to remove the frost.
I work at a grocery store and there were tons of cars in the parking lot. My coupe was the only car with frost on the inside.
My windshield was replaced about a month ago. This did no happen last winter.
Did the dealership mess something up? Boy do i hate them.
imdavit
Car: 08' Radiant Silver Altima Coupe 2.5s
same i got frost inside today, didnt think it was that big of a deal, but.. now im thinking different cuz u mentioned it.
Ferguson
Car: 09 3.5 SE Coupe
17 370Z Nismo
I live in the Great White North (Canada) and this morning it was close to -20, and no frost inside until my son and I got in the car - then, of course, our breath frosted everything. But after 5 minutes, that cleared. If you didn't have a window cracked open a hair then I can't see why you would have frost inside. Maybe there's an air leak somewhere around that new window?
dldjros69
Car: 2012 Evo Gsr
My dad asked me the same question - if i had the window cracked and no it was closed
I just drove to the mall - 50 mile round trip. I was doing about 70 and heard a rattle that i havent heard b4, i think its the windshield. There was also a whistling sound coming from the same area.
This was frost but when it did melt there was a ton of water, the rag i was using was really wet.
Ferguson
17 370Z Nismo
A rattle and whistle... sounds like that new windshield isn't sealed properly. If not, it would explain the frost. Go back to the installer/dealer and explain your problem... they should fix it.
dl_yeunuoc
Car: altima coupe
dldjros69 wrote:IThe "inside" of my windshield was covered in frost. I had to let my car warm up for about 20 minutes and use a rag to remove the frost
Me too. I have to turn on my defroster every night.
Ferguson
17 370Z Nismo
In California? You shouldn't have that!
Another possibility is a tiny pinhole leak somewhere in the heating system inside the car. That will also cause similar problems even if a fluid leak is not evident. But no one in Cali should have a frost problem!
Heels1010
i agree it doesn't sound like it is properly sealed in that area. The windshield should never make a whistling sound. How about the heat in the car when u drive it? do u find that your car never gets warm or that your heat is constantly running? We go snow here in new york and my windows never iced on the inside but plenty on the outside.
michaelthepsycho
Car: 09 Maxima S
Does mist on the inside count? I'm also in California. It seems my car stands out in terms of the misting =_= And the sad part is my windshield's OEM. Good thing Cali is more sunny and dry than cold and wet.
dldjros69
Car: 2012 Evo Gsr
My heater works great, the heat is 2 hot. I sit there sweating while the heat isnt defrosting my windshield.
When my windshield cracked i told nissan i wanted them to fix it. As i am pulling out of the dealership, i see an outside company working on my car in the parking lot. What jerks, they are going to get it now.
marlin29311
Car: 2008 Infiniti G35x
Are we talking about frost, or condensation?
Frost = frozen water particles requiring a scrapper to remove from windshield
Condensation = layer of watery film on glass
If you have frost on the inside of your windshield - that's really bad. If it's just condensation, I would before you turn your car off, change the vent direction from the defroster to something else (floor, etc). The car is an open entity, and you can't do much to prevent air/water from getting in.
dldjros69
Car: 2012 Evo Gsr
Oh yeah im talking "FROST".
I couldnt even remove the frost with a rag until the car was running and blowing heat for 5 to 10 mins. Then i was able to clear a path and leave work. I clean the rest of it at a few stop lights. The frost was flaking off onto my dash.
Cali 2 Balti G
Car: Desert Platinum G35 Coupe
Dodge Ram Quad Cab
Toyota Sequoia
marlin29311 wrote:Are we talking about frost, or condensation?
Uhhhhhhh doesnt condensation freeze below 32 degrees????????
I get that on my car too sometimes - my windshield is original.
CanadianCoupe
Car: 2008 Nissan Altima Coupe 2.5 S 6MT
If there is frost on the inside make sure you are running the air conditioner as the defroster is running, as the air cond. removes the moisture in the air. I dont know if this is a problem or if it is because of the cold.
I sell cars and everytime I get in a car now the inside is frosted, this is probably because we reached -40 degree's farenheit last week! Running the defroster on full with the air cond. on normally does the trick in about 5 minutes.
marlin29311
Not always - while the freezing point of water is 32 degrees, this is under ideal conditions for pure water. The condensation that forms on your windshield is much more than just water - dust, minerals, debris, etc - generally speaking, condensation on the inside of your car is very difficult to freeze effectively.
