r34 gtr wrote:I would say your engine seriously needs a rebuild. Pull it out, assess the damage, and go from there. When there is that much oil consumption, things are seriously wrong.
ca18detgabby wrote:time for a rebuild.
no sense in playing around with it.
It sure can. With the quantity of oil being consumed a good amount of that wont get burnt up and make its way into the turbine. Not a far distance to make it to the turbo.ks13 wrote:
cakeater, while burnt rings would explain the oil consumption, they wouldn't really explain oil being poured into the turbine housing.
I think the op meant to say turbine housing.
I re-read my response and it sounded d!ck. Not at all what I was going for.ks13 wrote:I stand corrected
Yes I meant turbine housing (the intake side of the turbo?) huge amounts of oil in thier that's where the majority of the oil consumption is at. Also IIRC the vac at idle is 20 but I didn't really look when I had it running I'll check it and let you know.ks13 wrote:
edit: if you do mean the compressor side of the turbo then the seals must be fubard? And if your compression is low, and headgaskets jacked up, then pull it.
On a side note It would be worth taking the cams out, and blowing air down into #4 cylinder to rule out pumped up lifters causing the low or no compression reading there, even with the cam on its basecircle if the lifter is pumped up Im pretty sure it will still hold the valve open But if its really POURING oil into the turbo, then i doubt its pumped up lifters. Whats does it pull for vac at idle?
Modified by ks13 at 7:27 PM 3/23/2010
Modified by ks13 at 7:38 PM 3/23/2010
So then I was right its the compressor side of the turbo the side where the intercooler hooks up to so basically a rebuild is needed that's what I thought as well so I guess she'll be gettin torn down thanks guys for all the help.float_6969 wrote:Compressor side is where the intercooler piping connects too, turbine housing is where the exhaust connects to.
If there is oil in the compressor housing it's because the blown rings/cracked ring land/damaged piston in #4 is increasing the blowby to the point that the oil can't drain out of the turbo like it needs to. Something that everyone needs to know, the oil seal rings on a turbo are NOT designed to handle any kind of oil setting up against them. They are NOT a positive seal, and if oil doesn't drain out of the turbo as quickly as possible, it WILL leak past the seals. This doesn't mean the seals are blown. Actually, if the turbo is so worn that the seals leak oil, the blades of the impellers would be contacting the housings. On the other hand, if the oil is backing up into the turbo, it will very easily just leak past the seal.
If it's in the turbine housing, it's probably from the blown rings drawing oil up into the combustion chamber. This is highly unlikely though, unless you've got like 0 compression.
Regardless, the only way to really fix this is to rebuild the motor. At the least it's going to need re-ringed.
