Hey man thanks.
I Actually think I found out what it was on one of the other forums. The engine mounts are actuated, and apparently there is a regular problem with the mounts not de-powering. There was a Nissan Service Bulletin published that describes the problem being a result of a problem between the engine mount and the ECM.
The Bulletin is right here.
http://www.nissanhelp.com/Owne...0.htm
A guy recognized my problem right away, and asked "You have an Auto right?". So I guess a lot of people have had this problem.
Have you, (Or anyone that wants to offer some advice) had any dealings with a dealer / manufacturer problem like this before? I know that the dealer here won't want to offer any help, as I have dealt with them before. What I want to know is, if anyone has dealt with something like this before, and how to approach the dealer with the problem.
Do I print off the bulletin and drop by to talk with a service manager casually, or should I built on whatever I can find about this and talk to the highest - ranking guy at the stealer-ship? I've dealt with the owner before, and he pretty much takes the stand that he can't do anything with problems that are out-of-warranty, while Nessan Canada won't listen to anything unless you have a current warranty either.
Is this something that should be covered outside of warranty?
