Niterider73 wrote:hello I have a few questions about my z i recently purchased, I believe yall have the knowledge of z's to help me out
Sometimes.
Niterider73 wrote:1. the fuel pump was replaced along with my tank sealed when the guy i bought it from put it all back together the digital fuel gauge no longer works. the low fuel light and the DTE still function but the gauge and number of gallons does not register what could this be?
Doubtful it worked before he took it apart then. But.... Define "doesn't work". Does it not light up ever? Does it provide an incorrect reading? Does it ever provide a reading? How many gallons are you putting in when the low fuel light comes on? Does it light up when you run the dash through the test mode? Are any of the other gauges working or not working?
Niterider73 wrote:2. what is the silver box that is plugged into the fuel pump and sending unit in the trunk?
Part of the signal conversion for the digital dash. Without it, the dash won't know what the appropriate signal is to display and won't display anything.
Niterider73 wrote:3. the new fuel pump constantly stays on even when just turning the ignition on, but not cranking the car, is that suppose to happen? if not could a relay be bad or something?
It should run for about 10 seconds or so after you turn the key to the "ON" position, but before you start the car.
Niterider73 wrote:4. the adjustable suspension functions for about 15 seconds (i can hear it when i select each, I can hear it in the suspension) but after the 15 or so seconds it starts to blink. Could this be worn out shocks?
You should NEVER hear them run. Ever. I'm not sure what you're hearing. Do you have the original shocks? It's unlikely they're any good anyway.
Niterider73 wrote:5. my avg. speed does not work just shows two little flat lines, I have turned it off and turned it back on but it dosen't register. What could this be?
It is supposed to take about 30 seconds of driving to register. If there is an issue with the speedometer or clock, it won't work.
Niterider73 wrote:6. Last question and is one of the most confusing so bare with me here, I dont know if my headlight switch is bad or not, reason being I have no interior lights, parking lights, or tail lights, I have brake lights though. If I turn to the parking lights on the switch nothing comes on at all, not even the animated voice dosent say anything about the lights being on with the key out of the ignition. Now if i turn to the headlights selection, just my headlights come on and its only the dims if i turn to brights, i have a headlight out light come on in the dash, no blue brights light showing, and if i turn on my brights the flip lights just go nuts. I have fiddled around with trying out different things and I have had my parking lights, interior, tail lights, and the voice come on. I accidentally stumbled upon this by replacing one of my tail light bulbs it required a 1157 bulb (two prongs on the end) and i was trying to put in a 1156 bulb (one prong on the end) in I had the brakes pushed in at the time, and when I put the 1156 bulb in all of my interior, parking, tails and the voice were on. What In the world could this be??? Please I need some help with these problems. I love my 300zx and want to restore her soon!
This is generally headlight switch related, but first you should check the fuses. Specifically, check the ILL fuse.. Make sure all the bulbs are correct. No. Using a single fillament bulb in a place where dual filament bulbs are required WILL NOT WORK. Might as well try deep frying that Thanksgiving turkey in 10W30. You got all those errors and warnings and stuff because you were using the wrong bulb. The car freaked out. Don't do that.
