merc68k »
https://forums.nicoclub.com/merc68k-u34529.html
Mon Oct 02, 2006 12:25 pm
Hi guys,
Does anyone in the forum drive a 98-01 Altima 5 speed? I am trying to figure out if the way mine behaves is normal or not. If I am stopped in neutral, and I ease into the gas, and bring the revs up slowly past 1000 rpm, at around 1200 rpm, the engine revs up on its own to around 2000 rpm, without my moving the pedal at all. If I ease off the gas at this point, the revs will drop back down to 1200; I can not hold the revs anywhere between 1200 and 2000 rpm! Before this car I had a 94 Altima which never did this.
On its own this is not such a big deal, but when I am driving along around 2000 RPM on a flat road, I get a pretty abrupt jolt when I ease into or out of the gas because I can not ease off the gas below 2000 rpm; they just drop down to almost idle once I cross a certain threshold.
If I disconnect the IACV valve, then the revving up goes away, and the abrupt response while driving also goes away, so I am wondering if there is something screwy causing this to happen, or if it is just the way they programmed the ECU in this model. I can not think of any reason they would want the revs to rise when I am already pressing the gas manually, so I suspect there is something weird going on.
Can anyone with the same era car PLEASE let me know if yours works the same way or not?
Thanks!
