Need help for Turbo t3/t04? T28bb?
thekawaii
Car: box with 4 wheels
Guys. Believe it or not, I'm reading Nico forums average 5 hours/day, just for researching. The only good place I know is NICO.
I got my final goal > 300~320whp with ca18det I know it's not easy to make 177hp/L.
What i Leanred:T28BB is not good after 300whpT3/T04 is bigger turboI concluded 300whp might stress T28BB so turbo will not last long?
BUt still don't know about A/R and Trim.Man.. this is really pain. i heard 48 trim but i could only found 50 trim.A/R i found .63 (don't even know what that mean)
What t3/t04 turbo do i have to buy? And any good place to buy? (So Cali)And what RPM does it starts to spool in CA18? 3500rmp?
(Reason i choose CA is faster, better higher rpm limit, cheap. KA vibrates too much even at 5000 rpm.)
c-rad
Car: 1991 Nissan 240SX w/CA18DET
thekawaii wrote:Guys. Believe it or not, I'm reading Nico forums average 5 hours/day, just for researching. The only good place I know is NICO.
T3/T04E 50-trim with a .48 turbine A/R would be a GREAT setup. Cheapturbo.com has em for $619. Keep in mind though, a T3/T4 setup is going to be much more expensive. You will need a topmount manifold, custom downpipe, external wastegate, and custom oil feed and return lines.
iliketocrash
in the end you'll spend as much if not a little more than a brand new BB turbo.
the t04e housing with the 50 trim is quite amazing in my opinion. very efficient across a broad range. broader than most in fact. the only problem i see (which might not be a problem for you, is that it'll be a little laggy, even with the .48 exhaust side. I think Dee might have used this same turbo build at one point or another se he's really the one who should be answering this =P It might be worth it to step down to something a little smaller if lag is a big issue. Myself, i paid a lot more money for my turbo than i should have (and i'm not going to say how much, EVER) but i talked to someone at turbonetics for about an hour over then phone about which turbo would be best for my car and my needs. Then i ordered that turbo from them... little expensive. But i think thinks worked out well in the end.
thekawaii
thanks guys
flohtingPoint
Car: 2004 Z16 Corvette Z06
Is your project horsepower just for multipurpose events/daily driving, or do you have a specific purpose you are designing your vehicle for, such as solo II, hill climbs, drag, etc?
float_6969
The previous question is probabally the most important. With that information, you can decide what leeway you have and where.
