need help for tomorrow, saturday
articzap
Car: 2014 F150 FX4
I need to know how to pull off the timing sprocket on the the crank so I can replace my oil pump. I'm open to any and all ideas.
What are the head bolt sizes so I can buy the right socket for it?
slo
Car: S13
All the info you'll need is in the stickies...
27mm bolt for the crank pully bolt
You'll need to take the little alignment pin out. I didn't have trouble with this but there's an alignment pin that must be taken out. Be care with this because some people accidently break the crank sprocket trying to do so.
Once you're done with that, have fun taking off the oil pan and you're home free~!
articzap
Car: 2014 F150 FX4
slo wrote:All the info you'll need is in the stickies...
Thats a little more helpful. I have motor stripped down. The only thing holding me back is the spocket. I tried pulling the key out, but it doesn't want to budge. I wasn't sure on how to pull that key out. And I searched trying to figure out both of my questions.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Drill and tap two holes in the gear, then make a puller and have at it. A flat bit of metal (really, really strong) with two holes in it and some good high-strength bolts should do it. Tighten them up evenly until it goes "sproing!"
capowered240
Car: 90 240sx
articzap wrote:What are the head bolt sizes so I can buy the right socket for it?
10mm allen socket.
