This is what you want Rubber Coil Spacer It's simple, lift the rear en up, slide it into the bottom of the coil as far as you can and you're done. I asked my underbody guy what he thought and he didn't have a problem with them. I'm not to going put something in that I felt could fail prematurely.Natedogg1701 wrote:So i'm lifting my 03 pathy, actually i should say i've lifted it. i got the kit from 4x4parts, along with every replacement bushing for my suspension, along with a whole lotta fun stuff. anyway i still want it to be a lil higher, now i know i can get strut spacers from the nx4 website, which bring up a question....which top mount spacer do i get? there are 2 offered. but wut really bugs me is i cant find coil spring spacers for the rear! i've heard of guys like emptyv using the rubber mr. gasket spacers, but in my opinion rubber wears out over time. does anyone know of any aluminum, or any type of metal spring spacers, even polyeurothane ones? or is there another vehicle with rear coil springs very similar to pathy springs, so i could buy spacers that way? i've seen somewhere that jeep grand cherokee v8's have coil springs that fir pathfinders, that true? i'de appreciate any help anyone can give, i've always had great luck with this forum, mostly every1 on here is very helpful.
That's exactly what I had on the 240Z. Don't get turned off because they arerubber. They work just fine.Empty V wrote:
When you lift up the rear end you'll be extending the coil springs well past an inch of the normal vertical stance. There's plenty of room to jam the spacers in there which will increase the ride height. I put them in the bottom of the coil springs thinking that it will prevent them from falling out.Natedogg1701 wrote:thanks empty, i was actually hoping this would catch your attention because i knew you had these spacers, just wasnt sure exactly how to find them, but those arent the spacers that like fit in between the spring andkeep it from compressing are they? they go on top or on bottom of the spring and actually give 1 inch of lift correct? another question, the strut spacers you have, the nx4 spacers, the site offers 2 different top mount spacers, and the difference between the two seesonly to be the size bolts you can get, which ones work for the R50?
