NEED HELP FINDING CHEAP SPRINGS
TRANCEBOY
Car: Rogue SL
i BELIEVE h@r is the only company that makes springs for the Rogue which really sucks as the price is really high. Does anyone know where i can get these cheap. Best price ive seen was like 256 dollars.
Anyone selling any used ones. Or does eibach make a spring which will fit ?
Leo2005
Found a better deal for $251: http://www.jayracing.com/index.php?main ... s_id=11148 :chuckle:
And if you google it then you'll find a little better deals like on tirerack for $218:
http://www.tirerack.com/suspension/susp ... toModClar=
TaiLuu
Car: 2009 Nissan Murano LE AWD
2011 Nissan Rogue SV AWD
2014 Nissan Pathfinder Platinum
Lowering springs are bad for the chassis anyways so you'll probably end up spending more on the car.
philipa_240sx
Tranceboy,
~$250 is not very expensive for springs. If anything that's about as cheap as you'll find anywhere!
Save up the coin and buy the H&R's. Also make sure you get a 4 wheel alignment once you are done otherwise all that money you just spent on tires is going down the tubes. Lowering a car changes the wheel alignment and can wear out tires unevenly in just one year of driving!
Return to “Rogue Forum”
