MONSTRUM wrote:Hey guy, would these rims fit nicely on stock body 5-lug S14?
Front 18X8.5 Offset +32mm Rear 18X9.5 Offset +43mm
Tires would be 255/35/18 and 275/35/18 drag radials in the back.
Please let me know.
Thanks,W
That would work but the first comment you will hear is: "YOU SUNK MY BATTLESHIP!!!"
I would go with this setup but you will need to roll fenders:
18x8.5 +15 with hi disk 225/40-1818x9.5 +20 with low disk 245/40-18
This setup will give you a fat lip, clear big brakes and clear coilovers as well. Then again, it might not be right for you. What are the goals of the car?
