Need Help Fast
Post all your Nissan electronics, car audio and stereo questions here!
nv3713
Car: 93 Nissan Max
Hey, I am a first time Nissan owner. Recently i bought a 93 Max. Problem is i have an issue with the factory alarm. I can unlock the doors with my key but when i open the door the alarm goes off on me. I cant get the alarm to turn off now. And, as you may know, this doesen't allow the car to start. I have tried everyting from puting the key in the door and turning left then right then center but still nothing. I am going to try to do the glove box keypad reset thing tonight but i have read that doesen't always work either. Any suggestions? I do not have the factory key to the car nor do i have the keyless entry/alarm remote either. Do you have anything i could try?
Thanks to those that reply.
Looneybomber
Car: 02 explorer sprt (grn)
10 G37S (white)
Can you get a wiring diagram, see what circuit it's on and pull that fuse? There's nearly a 100% chance there are multiple things tied into that circuit though, so pulling that fuse could also disable other things.
