Need help fast starter problems rhd sr20 91240sx
Innocent-S13
Ok guys i have a right hand rive converted 91 240sxIt has an s14sr20 in it.im having serious starter problemsThe car worked fine a few days ago started and everythingNow When i turn the key its a constant click no power drainage checked all fuses are good and battery is good. I took the starter off and it works.Idk what else to check but i need this thing running asap
D-UNIT
Car: a 91' S13 (15.014 @ 94.56mph NA) KA-T
rapid fire clicking = dead or no good batt. or bad connection from Battery to solenoidsingle click or super slow cranking = bad starter or bad ground
check all . try tapping starter while someone else cranks it. use hammer and thin pipe. if that works starter no good.
