NEED HELP FAST.. running lights and tail lights
R4KA240
Car: 1990 coupe with "Stock" KA24E, 1994 Convertible, 1989 coupe (motor T.B.D.)
My running lights, meaning my tail lights and ambers DO NOT WORK when i flip the lights on, nor when I flip it to headlights too, healights come up and work, also my dash cluster lights DO NOT WORK... I am searching but have work tonight and NEED HELP! and no, the fuse isn;t blown
Malac0da13
Car: 1992 Nissan 240SX Convertible
did u try troubleshootin with the fsm
R4KA240
currently trying it and the wires seem fine.. I'm still trying..
Glyph
Car: 1993 Nissan 240SX Converible
I guess it seems obvious but you may want to try your fuses. I used to have a Prelude that when (if?) the running lights went out, so did the cluster gauge lights. It was specifically designed as a warning to let you know about the problem.
R4KA240
Thanks, and I already tried that... sometimes the stupid things are what we overlook but this time I've checked everything I can think of.. a friend said I may have fried a wire or something, I was hooking up a gauge today useing the little connector you hook onto a fuse, but got no where near ANY of the lights fuses... To be more specific about whats going on, cluster, ambers, tail lights don't work, blinkers, headlights, brake lights, and rev. lights all do, the headlights take a bit before they go down now too.. if that points out anything to anyone at this point its just..
wmdavis007
Car: 1992 240SX Convertible
1997 Jeep Wrangler Sahara 4.0L
I had the same problem and just fixed it today. Find the fuse for the lights and take it out...then use a small flat screwdriver, bend the prongs inward so they make better contact on the fuse. This is what was wrong with mine. The people that had the car before me had a cell phone installed and the installer used one of those fuse adapters to get power...so when I took it out the prongs were spread out and didn't make a good conection. I hope this will fix yours cause I spent days of troubleshooting with the FSM and a Fluke meter. Good luck!
Modified by wmdavis007 at 10:49 AM 9/15/2006
jamesblonde82
Car: 1992 Nissan 240SX convertible RIP 5/10/07
1993 Nissan 240SX convertible
the turn signal switch to turn the lights on and off could be worn to where its not making contact. if all else fails you might need a new switch.
Malac0da13
did u check if there was power goin thru where the fuse is...thats the only thing i can think of if all that stuff isnt werkin and stopped werking at the same time...
R4KA240
wmd - no such luck.. checking the fuse relay now with a power meeter, had to bum a ride to work, school, and work this afternoon too.... just got home and I'm attempting a full run down...
R4KA240
Can anyone tell me where ALL the relays are in this system... I need a FULL FSM so I don't know if I know where they ALL are... Thanks... also, how do you take off the switch on the dash, the knob that operates the parking lights/headlights..
wmdavis007
The running light/headlight stalk is removed by taking off the steering column cover...then the stalk is removed by unpluging the two harnesses and the two screws...then it just slides out
R4KA240
I had never looked at it before so I didn't know it was that simple, thanks, but I GOT IT FIXED!!!! in the display lights control box, some of the solder had heated up and was bridgeing a connection.. BARELY noticed it but obviously it was enough.. Thanks everyone, another 'vert back on the road
