Tash wrote:My 1993 240SX (KA)Failed emission –CO,HC
NJ inspection spec
CO spec:0.76-> 5.25HC spec:136-> 196
There is no “ Service Engine” warning.Car runs OK,Please give me suggestions to fix this problem.
HC levels are high because your timing isn't adjusted correctly. Anything above 21 BTDC will raise HC's. You want it between 19~20BTDC. 19BTDC is always fool proof for smog.CO could be raised because you have bad spark plugs, or just overall bad electrical. Insanity could also be right about the O ring failure.
Modified by Bigvinnie at 7:04 PM 12/6/2006
