nametakennow »
https://forums.nicoclub.com/nametakennow-u713.html
Thu Aug 20, 2009 11:47 am
Try the manual method of checking codes. It's in the Common Fixes thread in the ToC if I recall.
Still sounds like a fuel pump issue, specifically the electrical connection to the pump. Either rig some way to keep the connector very tight or find a correct pump that fits (check part numbers).
Of course, call your dealer and ensure all recalls were taken care of. I don't think the fuel pump one was for the 02s, but it's worth a shot. Possibly the ECU foam one could apply to you.
