NEED HELP ENGINE WILL NOT START
chorthaoM3
Car: 96 BMW M3, 93 240sx
I just did a sr20det swap into a s13.. The engine will not start.. The motor cranks but there seems to be no spark... The fuel pump also dosn't come on.Things I did alreadyCheck fuel pump fuseDouble check my wiringECU has powertrying it with my firend's good ignitor chipeverything comes on but the fuel pump
Thanks for any help
Alastaplat
Car: 1989 240sx
well when you go this new engine... did you happen to know who owned it before you to know weather or not everything was in working order??
Silvia007
Car: 93 Nissan 240SX SE Fastback
Well... test for spark to confirm there's spark. If you are unsure if the fuel pump works, the easiest way to confirm is have a empty milk jug around and unclip the fuel line and stick it into the jug, have someone crank it for a second to see if fuel comes out.
My money is either the wiring and/or ignitor... but then again, S13 wiring is ultra easy to rewire so there shouldn't have been any issues there.
Also, make sure you redo the timming. Pull the CAS and perform the proper proceedure on resetting it.
Hey, you're in st.paul, so am I. If you need help. E-mail me.
chorthaoM3
I have check for spark already and there's no spark. When I bought it, they said they did a compression test and it was good. Hey silvia007 do you know a lot about it. If so mybe you can come and take a look.. Let me know.
180fan
Car: 89 fastback
no spark, check if it's a cas or ignitor issue.
