DeeZX »
https://forums.nicoclub.com/deezx-u100654.html
Sun Aug 22, 2010 6:04 am
Don't know if you found your problem yet. but I think it might be your Crank Angle Sensor (CAS). The dowel that keeps it in position could be worn down or miss shaped and its shaky.
Another possibility could be a corroded fuse, in particular, the 10 amp fuse labeled ECU in your under hood fuse box. This recently happen to me. Before I found this, my Z displayed similar symptoms.
