Hi all, I made a mistake by cleaning my throttle body while the engine was one with some brake cleaner. The car immediately stalled and my check engine like came on, PO136. I reset the light a few times and it pops back on 20 miles later. The manual says to check for intake leaks, which I've done numerous times, visually, without success. Should I change the cat and second 02 sensor? I need to smog the car. The vehicle sniffs clean but won't pass with the engine light on. Is there a way to bypass the sensor to get rid of the light, perhaps?thanks in advance for any help!![email protected]
Modified by Scirocco16v at 1:20 PM 8/9/2006
