NEED HELP!!! engine has no sparks.
chorthaoM3
Car: 96 BMW M3, 93 240sx
I need help. Just got done wiring my sr20det. Every thing works, except that I am getting no sparks and the fuel pump won't come on. Please help.
180fan
Car: 89 fastback
tested the ecu yet?
chorthaoM3
I try it with my firend's ECU and it still didn't work.
180fan
Car: 89 fastback
no spark - check the ignitor with a multimeter to see if that's in working order, if that fails - replace, otherwise move to the cas.
fuel pump, check the fuse yet?
chorthaoM3
I try it with my firends ignitor it still didn't work. I tested the plug by the ignitor and I'm no voltage at all. For the pump I have check all the fuse and they all seems to be ok.
tufortesx
Check for grounds. Was the harness cut?
chorthaoM3
yes
180fan
Car: 89 fastback
aw crap...cut harness...who repaired it and where was the cut?
tufortesx
180fan wrote:aw crap...cut harness...who repaired it and where was the cut?
Thats what I was thinking. cut harness= . Me personally I would contact heavy throttle. I believe their harness repair service is only like $100. I did my first DET swap in a 1.6 sentra quite some time ago. I went through about 5 hacked harnesses. Even tho the car ran it was crappy. When I finally got a good harness in there it started the first time and every time after that. Just food for thought. Hope it helps
